Ir para o conteúdo principal
Lenovo Yoga 11e Chromebook Battery Replacement
O que você precisa
  1. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the back panel: passo 1, imagem 1 %32
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery screws: passo 2, imagem 1 %32
    • There will be 2 other Philips screws under the cover there should also be two arrows pointing at each screw that needs to be removed.
  3. Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: passo 3, imagem 1 %32 Lenovo Yoga 11e Chromebook Battery Replacement, Removing the battery: passo 3, imagem 2 %32
    • Pull up the battery slightly by the tab and pull back
    • Remove the connector from the motherboard and pull the battery up and away from the board
    • Make sure not to pull all the way back as the battery is still connected to the motherboard
    • The computer may not boot when you try to turn it on, plug it into its power supply and it should boot.
Conclusão
Congratulations! You hopefully have successfully completed this guide! To reassemble your device follow the steps backwards.
4 outras pessoas executaram este guia.
Corey Meyer
Membro desde: 05/01/17
2.268 Reputação
Autoria de 2 guias
Equipe
Kid fixers Membro de Kid fixers
Community
Membros da 156
Autoria de 292 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 3,064
