Ir para o conteúdo principal
Lenovo YOGA 730-15IWL Battery Replacement
O que você precisa
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: passo 1, imagem 1 %32
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: passo 2, imagem 1 %32
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: passo 3, imagem 1 %32
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
Conclusão
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membro desde: 04/22/20
40.418 Reputação
Autoria de 16 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.077 guias
2 comentários
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Responder
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 52
Duração total: 1,473
