Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pry up the bottom cover with an opening tool.
Start at the front edge of the cover and make your way along the sides.
Pull the bottom cover up and away from the back hinges.
Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
Remove the four 4mm Phillips #1 screws securing the battery.
Pull up on the black tab on the touchpad cable connector.
The ribbon cable should easily pull out of the connector.
Pull up on the top edge of the touchpad near the motherboard. Lift the touchpad up and out of the chassis.
