Ir para o conteúdo principal
Lenovo YOGA 730-15IKB Touchpad Replacement
O que você precisa
  1. Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Touchpad Replacement: passo 2, imagem 1 %32 Lenovo YOGA 730-15IKB Touchpad Replacement: passo 2, imagem 2 %32
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Touchpad Replacement: passo 3, imagem 1 %32
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: passo 4, imagem 1 %32 Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: passo 4, imagem 2 %32 Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Touchpad Replacement: passo 5, imagem 1 %32 Lenovo YOGA 730-15IKB Touchpad Replacement: passo 5, imagem 2 %32
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Touchpad Replacement: passo 6, imagem 1 %32
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: passo 7, imagem 1 %32 Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: passo 7, imagem 2 %32 Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: passo 7, imagem 3 %32
    • The touchpad is connected by a ribbon cable to the front edge of the motherboard.
    • Pull up on the black tab on the touchpad cable connector.
    • The ribbon cable should easily pull out of the connector.
  8. Lenovo YOGA 730-15IKB Touchpad Replacement: passo 8, imagem 1 %32
    • Remove six 2mm Phillips #000 screws.
    • Some of these screws may be hidden under other ribbon cables.
  9. Lenovo YOGA 730-15IKB Touchpad Replacement: passo 9, imagem 1 %32 Lenovo YOGA 730-15IKB Touchpad Replacement: passo 9, imagem 2 %32
    • Pull up on the top edge of the touchpad near the motherboard. Lift the touchpad up and out of the chassis.
Conclusão
Equipe
Cal Poly, Team S1-G6, White Winter 2020 Membro de Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 1,583
