Ir para o conteúdo principal
Lenovo YOGA 730-15IKB Speaker Replacement
O que você precisa
  1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Speaker Replacement: passo 2, imagem 1 %32 Lenovo YOGA 730-15IKB Speaker Replacement: passo 2, imagem 2 %32
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Speaker Replacement: passo 3, imagem 1 %32
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: passo 4, imagem 1 %32 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: passo 4, imagem 2 %32 Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: passo 4, imagem 3 %32
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Speaker Replacement: passo 5, imagem 1 %32 Lenovo YOGA 730-15IKB Speaker Replacement: passo 5, imagem 2 %32
    • When the laptop is upside down, the left speaker is located on the right side of the computer.
    • Pull up on the left speaker to remove it from the chassis.
    • Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
  6. Lenovo YOGA 730-15IKB Speaker Replacement: passo 6, imagem 1 %32
    • Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
  7. Lenovo YOGA 730-15IKB Speaker Replacement: passo 7, imagem 1 %32 Lenovo YOGA 730-15IKB Speaker Replacement: passo 7, imagem 2 %32
Conclusão
Ellis Ruckman
Membro desde: 01/23/20
2.545 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G6, White Winter 2020 Membro de Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
Membros da 3
Autoria de 27 guias
Um comentário
when the stock can arrive ?
prashantdushara - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 826
