Ir para o conteúdo principal
Lenovo YOGA 730-15IKB Right Fan Replacement
O que você precisa
  1. Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 2, imagem 1 %32 Lenovo YOGA 730-15IKB Right Fan Replacement: passo 2, imagem 2 %32
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 3, imagem 1 %32
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Right Fan Replacement, Right Fan: passo 4, imagem 1 %32
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 5, imagem 1 %32 Lenovo YOGA 730-15IKB Right Fan Replacement: passo 5, imagem 2 %32
    • Remove two 4mm Phillips #1 screws.
  6. Lenovo YOGA 730-15IKB Right Fan Replacement: passo 6, imagem 1 %32
    • Pull the fan up and towards the front of the laptop.
Conclusão
Equipe
Cal Poly, Team S1-G6, White Winter 2020 Membro de Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Duração total: 2,845
