Introdução
In this guide, the reader will go through the necessary instructions needed to replace a non-functioning motherboard in the Lenovo Y50-70 Touch Laptop. This specific repair does not require any previous knowledge about computers and can be completed by a beginner using only a single Phillips #1 screwdriver and a small plastic prying tool.
When performing this repair, ensure you are in a static free environment so as not to provide an electrical shock to the computer and possibly further damage the device.
O que você precisa
Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
Grab and pull off the back.
3 outras pessoas executaram este guia.
