Ir para o conteúdo principal
Lenovo Y50-70 Touch Fan Replacement
O que você precisa
  1. Lenovo Y50-70 Touch Fan Replacement, Back: passo 1, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement, Back: passo 1, imagem 2 %32
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: passo 2, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement: passo 2, imagem 2 %32
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: passo 3, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement, Fan: passo 3, imagem 2 %32
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: passo 4, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement: passo 4, imagem 2 %32 Lenovo Y50-70 Touch Fan Replacement: passo 4, imagem 3 %32
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: passo 5, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement: passo 5, imagem 2 %32 Lenovo Y50-70 Touch Fan Replacement: passo 5, imagem 3 %32
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: passo 6, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement: passo 6, imagem 2 %32 Lenovo Y50-70 Touch Fan Replacement: passo 6, imagem 3 %32
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: passo 7, imagem 1 %32 Lenovo Y50-70 Touch Fan Replacement: passo 7, imagem 2 %32
    • Lift the fan off of the laptop.
Conclusão
8 outras pessoas executaram este guia.
Vivian
Membro desde: 01/21/15
351 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-1, Maness Winter 2015 Membro de Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membros
15 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 9,173
