Ir para o conteúdo principal
Lenovo Y50 Touch RAM Replacement
O que você precisa
  1. Lenovo Y50 Touch RAM Replacement, RAM: passo 1, imagem 1 %32 Lenovo Y50 Touch RAM Replacement, RAM: passo 1, imagem 2 %32
    • Place laptop on a flat surface with the back cover facing up.
    • Remove all twelve 6 mm long screws on the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
  2. Lenovo Y50 Touch RAM Replacement: passo 2, imagem 1 %32 Lenovo Y50 Touch RAM Replacement: passo 2, imagem 2 %32
    • Gently pull off the back cover of the laptop. It should come off easily.
  3. Lenovo Y50 Touch RAM Replacement, Locate the RAM: passo 3, imagem 1 %32
    • The RAM should be located at the indicated area inside the laptop.
  4. Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: passo 4, imagem 1 %32 Lenovo Y50 Touch RAM Replacement, Unclamp the RAM: passo 4, imagem 2 %32
    • Release the clamps securing the RAM by pushing each clamp away from the RAM.
    • Once the clamps are released, the RAM should be facing outward at an angle.
  5. Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, imagem 1 %32 Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, imagem 2 %32 Lenovo Y50 Touch RAM Replacement, Remove the RAM: passo 5, imagem 3 %32
    • Gently unplug the RAM from its port.
    • Do not bend or drop the RAM, as this can affect its function.
    • You can replace up to two RAM sticks for this laptop. Just repeat step 4 for the second RAM port.
    • Pay attention to the arrangement of the pins on the RAM. When replacing the RAM, make sure the pins line up with the pins on the RAM port.
Conclusão
9 outras pessoas executaram este guia.
Andrew Tran
Membro desde: 01/21/15
814 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 18-1, Maness Winter 2015 Membro de Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membros
15 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 5,038
