Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will document the process of upgrading or replacing memory in a Lenovo X200 laptop or tablet.
O que você precisa
1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
Insert the notched end of the DIMM into the socket.
Press the DIMM firmly, and pivot it until it snaps into the place.
Make sure that it is firmly fixed in the slot and does not move easily.
4 outras pessoas executaram este guia.
