Ir para o conteúdo principal
Lenovo X200 Memory Replacement
O que você precisa
  1. Lenovo X200 Memory Replacement, Memory: passo 1, imagem 1 %32
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. Lenovo X200 Memory Replacement: passo 2, imagem 1 %32
    • 2. Remove the panel to access the memory modules.
  3. Lenovo X200 Memory Replacement: passo 3, imagem 1 %32
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
Conclusão
4 outras pessoas executaram este guia.
James Finch
Membro desde: 10/14/17
2.268 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,143
