Ir para o conteúdo principal
Lenovo Vibe Z2 Pro Screen Replacement
O que você precisa
  1. Lenovo Vibe Z2 Pro Screen Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: passo 1, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: passo 1, imagem 2 %32
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Screen Replacement: passo 2, imagem 1 %32
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Screen Replacement: passo 3, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 3, imagem 2 %32
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Screen Replacement: passo 4, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 4, imagem 2 %32
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Screen Replacement: passo 5, imagem 1 %32
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Screen Replacement, Battery: passo 6, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement, Battery: passo 6, imagem 2 %32
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Screen Replacement: passo 7, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 7, imagem 2 %32
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Screen Replacement: passo 8, imagem 1 %32
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Screen Replacement: passo 9, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 9, imagem 2 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 9, imagem 3 %32
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Screen Replacement, Motherboard: passo 10, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement, Motherboard: passo 10, imagem 2 %32 Lenovo Vibe Z2 Pro Screen Replacement, Motherboard: passo 10, imagem 3 %32
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Screen Replacement: passo 11, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 11, imagem 2 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Screen Replacement: passo 12, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 12, imagem 2 %32
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Screen Replacement: passo 13, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 13, imagem 2 %32
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Screen Replacement: passo 14, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 14, imagem 2 %32
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Screen Replacement: passo 15, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 15, imagem 2 %32
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Screen Replacement: passo 16, imagem 1 %32
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Screen Replacement: passo 17, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 17, imagem 2 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 17, imagem 3 %32
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
  18. Lenovo Vibe Z2 Pro Screen Replacement, Ear Piece Speaker: passo 18, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement, Ear Piece Speaker: passo 18, imagem 2 %32
    • Gently lift the speaker out of its housing by inserting the tweezers under the speaker.
  19. Lenovo Vibe Z2 Pro Screen Replacement, Charging Assembly & Headphone Jack: passo 19, imagem 1 %32
    • Remove the 3.6 mm Phillips head screws from the charging assembly
  20. Lenovo Vibe Z2 Pro Screen Replacement: passo 20, imagem 1 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 20, imagem 2 %32 Lenovo Vibe Z2 Pro Screen Replacement: passo 20, imagem 3 %32
    • Gently peel the flat cable away from the screen
    • Gently lift the charging assembly using a spudger
  21. Lenovo Vibe Z2 Pro Screen Replacement, Screen: passo 21, imagem 1 %32
    • Your device is now ready for reassembly with the replacement screen.
Conclusão
Jemma Hunter
Membro desde: 10/04/16
215 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 18-3, Blackwell Fall 2016 Membro de USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Membros
Autoria de 12 guias
3Comentários do guia
can the glass and LCD be separated after step 21?
allen immaraj - Responder Compartilhar
No, it can’t. It strips te polarizing layer off the LCD and ruins it, so dont buy just the digitizer to repair. Having said that, also dont buy the LCD either as its not worth the cost as a new phone will be cheaper or similar price.
Shig Bergin - Responder Compartilhar
I broke my vibe z2pro screen, can anyone recommend a cheap but good display available for replacement?
Thank you!
xaosrobot - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 4,394
