Introdução
If after replacing your battery, your phone is still not charging, you might have a faulty charging assembly. Learn how to replace it in this guide
O que você precisa
Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
Remove the 3.6 mm Phillips head screws from the charging assembly
