Ir para o conteúdo principal
Lenovo Vibe Z2 Pro Battery Replacement
O que você precisa
  1. Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: passo 1, imagem 1 %32 Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: passo 1, imagem 2 %32
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Battery Replacement: passo 2, imagem 1 %32
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Battery Replacement: passo 3, imagem 1 %32 Lenovo Vibe Z2 Pro Battery Replacement: passo 3, imagem 2 %32
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Battery Replacement: passo 4, imagem 1 %32 Lenovo Vibe Z2 Pro Battery Replacement: passo 4, imagem 2 %32
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Battery Replacement: passo 5, imagem 1 %32
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Battery Replacement, Battery: passo 6, imagem 1 %32 Lenovo Vibe Z2 Pro Battery Replacement, Battery: passo 6, imagem 2 %32
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Battery Replacement: passo 7, imagem 1 %32 Lenovo Vibe Z2 Pro Battery Replacement: passo 7, imagem 2 %32
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Battery Replacement: passo 8, imagem 1 %32
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Battery Replacement: passo 9, imagem 1 %32 Lenovo Vibe Z2 Pro Battery Replacement: passo 9, imagem 2 %32 Lenovo Vibe Z2 Pro Battery Replacement: passo 9, imagem 3 %32
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
Conclusão
4 outras pessoas executaram este guia.
Bryan Sepulveda
Membro desde: 09/15/16
547 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 18-3, Blackwell Fall 2016 Membro de USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
Membros da 4
Autoria de 12 guias
2 comentários
Where to buy such battery?
Damir Dominko - Responder
wala pa po ba dito s pinas ng bl230?
eduardo santos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 3,364
