Ir para o conteúdo principal
Lenovo V15-ADA Hard Disk Drive (HDD) Replacement
O que você precisa
  1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: passo 1, imagem 1 %32 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: passo 1, imagem 2 %32
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 2, imagem 1 %32 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 2, imagem 2 %32
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
    • Pop off the back plate and set aside.
  3. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: passo 3, imagem 1 %32 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: passo 3, imagem 2 %32 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: passo 3, imagem 3 %32
    • To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
  4. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 4, imagem 1 %32 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 4, imagem 2 %32 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 4, imagem 3 %32
    • The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
    • M2 × 6 mm, Phillips-head, nylok-coated (3)
  5. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 5, imagem 1 %32
    • Remove the battery from the device after completing steps 1 and 2.
  6. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Hard-Disk Drive (HDD): passo 6, imagem 1 %32
    • Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
  7. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 7, imagem 1 %32
    • Grasp the hard drive and lift up.
  8. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 8, imagem 1 %32
    • Pull the hard drive from its port.
  9. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: passo 9, imagem 1 %32
    • The hard drive has been successfully taken out.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 43
Ao todo: 400
