Introdução
If your device isn’t charging or loses charge quickly, it may be time to replace the battery. Follow the instructions below to replace the battery in the Lenovo V15-ADA.
Before you begin this repair, make sure your laptop is powered off and unplugged from the charger.
O que você precisa
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
