Ir para o conteúdo principal
Lenovo V14-ADA Battery Replacement
O que você precisa
  1. Lenovo V14-ADA Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Battery Replacement: passo 2, imagem 1 %32
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Battery Replacement: passo 3, imagem 1 %32 Lenovo V14-ADA Battery Replacement: passo 3, imagem 2 %32
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Battery Replacement, Battery: passo 4, imagem 1 %32 Lenovo V14-ADA Battery Replacement, Battery: passo 4, imagem 2 %32
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
Conclusão
Samaya Roukoz
Membro desde: 03/19/24
253 Reputação
Autoria de 3 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 32
Ao todo: 131
