Ir para o conteúdo principal
Lenovo Touch Y70-70 Motherboard Replacement
O que você precisa
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: passo 2, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 2, imagem 2 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 2, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: passo 3, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 3, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 4, imagem 2 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 4, imagem 3 %32
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: passo 5, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 5, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: passo 6, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: passo 7, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 7, imagem 2 %32
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 8, imagem 2 %32 Lenovo Touch Y70-70 Motherboard Replacement: passo 8, imagem 3 %32
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
Conclusão
Equipe
IUPUI, Team S2-G5, Harley Fall 2019 Membro de IUPUI, Team S2-G5, Harley Fall 2019
IUPUI-HARLEY-F19S2G5
Membros da 2
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 22
Duração total: 1,028
