Ir para o conteúdo principal
Lenovo Touch Y70-70 Hard Drive Replacement
O que você precisa
  1. Lenovo Touch Y70-70 Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Hard Drive Replacement: passo 2, imagem 1 %32
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Use the Phillips #0 screwdriver to unscrew the four screws.
  4. Lenovo Touch Y70-70 Hard Drive Replacement: passo 4, imagem 1 %32
    • Disconnect the hard drive from the motherboard.
  5. Lenovo Touch Y70-70 Hard Drive Replacement: passo 5, imagem 1 %32
    • Use the Phillips #0 screwdriver to unscrew the four screws on the sides of the hard drive frame.
    • Remove the hard drive from the frame.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Duração total: 2,601
