Ir para o conteúdo principal
Lenovo Thinkpad X240 RAM Replacement
O que você precisa
  1. Lenovo Thinkpad X240 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Flip the laptop up side down as shown in the photo.
  2. Lenovo Thinkpad X240 RAM Replacement: passo 2, imagem 1 %32 Lenovo Thinkpad X240 RAM Replacement: passo 2, imagem 2 %32
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo Thinkpad X240 RAM Replacement: passo 3, imagem 1 %32
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Lenovo Thinkpad X240 RAM Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X240 RAM Replacement: passo 4, imagem 2 %32
    • Remove the RAM stick by carefully popping its holders out of place.
Conclusão
6 outras pessoas executaram este guia.
2 comentários
Does this Thinkpad really have only one RAM slot? Or is there another one on the back of the board (i.e. under the keyboard)?
Sebastian Swirski - Responder
Would I be able to add a 16gb ram stick in it? Even though the highest spec config that the laptop ships with is only 8gb?
Mahir Max - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 28
Duração total: 4,653
