Ir para o conteúdo principal
Lenovo Thinkpad X220 Trackpad Replacement
O que você precisa
  1. Lenovo Thinkpad X220 Trackpad Replacement, Trackpad: passo 1, imagem 1 %32
    • Turn laptop over to expose the battery.
    • Slide and unlock the sliders while removing the battery casing at the same.
    • Place battery in a safe spot.
  2. Lenovo Thinkpad X220 Trackpad Replacement: passo 2, imagem 1 %32
    • Grab the Phillips screwdriver with the JIS, J00 head.
    • Remove all screws on the backside where the battery was removed.
    • You should have 10 screws total.
    • Place the 10 screws in a safe spot.
  3. Lenovo Thinkpad X220 Trackpad Replacement: passo 3, imagem 1 %32
    • Remove the plate next to the battery.
    • Remove the side panel.
  4. Lenovo Thinkpad X220 Trackpad Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X220 Trackpad Replacement: passo 4, imagem 2 %32 Lenovo Thinkpad X220 Trackpad Replacement: passo 4, imagem 3 %32
    • Close laptop.
    • Flip laptop over to battery side is facing down.
    • The screen needs to be open when separating the keyboard and trackpad from the base.
    • Using the Metal Spudger, place between the trackpad and the keyboard and lift up to remove.
    • Pull keyboard towards yourself.
    • Grab the tab on the ribbon wire, pull off to release the keyboard.
  5. Lenovo Thinkpad X220 Trackpad Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad X220 Trackpad Replacement: passo 5, imagem 2 %32 Lenovo Thinkpad X220 Trackpad Replacement: passo 5, imagem 3 %32
    • Now, you can get to the trackpad ribbon wire.
    • The trackpad ribbon wire in blue, unhinge the clamp to release the blue ribbon wire.
    • Get a hold of the trackpad and pull up and out of the laptop.
    • Carefully slide new trackpad into the hinges.
    • With the keyboard, clamp the ribbon back into place.
    • Slide replacement keyboard in.
    • Press the sides of the keyboard to secure placement.
    • New trackpad is now ready to be used, make sure it is in place and secure.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 36
Duração total: 5,216
