Locate the two switches that lock the battery.
Then push the left switch outward into the "unlocked" position.
Using the Metal Spudger, place between the trackpad and the keyboard and lift up to remove the keyboard and trackpad.
Pull keyboard towards yourself.
Grab the tab on the ribbon wire, pull off to release the keyboard.
Pull keyboard towards yourself exposing the ribbon wire that attaches it.
Grab the tab on the ribbon wire and pull up to release.
4 outras pessoas executaram este guia.
2 comentários
this is an absolutely awful guide...do not unscrew all those screws and do NOT use a metal spludger unless you want chips of plastic flying everywhere.
Jesus.
