Ir para o conteúdo principal
Lenovo Thinkpad X220 HDD Replacement
O que você precisa
  1. Lenovo Thinkpad X220 HDD Replacement, HDD: passo 1, imagem 1 %32
    • Put the laptop upside down.
  2. Lenovo Thinkpad X220 HDD Replacement: passo 2, imagem 1 %32 Lenovo Thinkpad X220 HDD Replacement: passo 2, imagem 2 %32
    • Unscrew the HDD slot cover.
  3. Lenovo Thinkpad X220 HDD Replacement: passo 3, imagem 1 %32 Lenovo Thinkpad X220 HDD Replacement: passo 3, imagem 2 %32
    • You will arrive to something like this.
    • Pull the black tab popping out to remove the HDD from its tray.
    • The little black tab can be fragile. I recommend you to put tape on it when you have removed the HDD from the bracket to make it tougher.
  4. Lenovo Thinkpad X220 HDD Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X220 HDD Replacement: passo 4, imagem 2 %32
    • Congratulations! You got the HDD out of the laptop. We can now put the laptop somewhere else and focus on the HDD.
    • On each long side of the HDD, two rubber bands are located. Pull them to remove them and access to the screws.
  5. Lenovo Thinkpad X220 HDD Replacement: passo 5, imagem 1 %32
    • Unscrew the 4 screws located on the two long sides of the drives...
    • ...and push the HDD outside from its retention bracket.
  6. Lenovo Thinkpad X220 HDD Replacement: passo 6, imagem 1 %32
    • You're done! To reassemble, place a new drive in the bracket and follow the steps in the reverse order.
Conclusão
13 outras pessoas executaram este guia.
alphaLONE
Membro desde: 07/01/11
876 Reputação
3 Guias de autoria
5 comentários
I just hope that a 64 year old crazy cat lady can do this without blowing up the galaxy
Bobbi Johnson - Responder
What size drives will fit?
Dan - Responder
7mm thick, no more. (I tried with a thicker HyperX 240gb drive but it was too big, wouldn’t fit)
alphaLONE -
eine feine Anleitung. Bravo!
Leitner Josef - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 23
Últimos 30 dias: 109
Duração total: 14,984
