Introdução
This guide shows you how to remove and replace the battery in your Lenovo X220.
O que você precisa
Locate the two switches that lock the battery.
Then push the left switch outward into the "unlocked" position.
To reassemble your device, follow these instructions in reverse order. Don't forget to switch the left switch back into the locked position.
3 outras pessoas executaram este guia.
