Ir para o conteúdo principal
Lenovo Thinkpad X201 Tablet RAM Replacement
O que você precisa
  1. Lenovo Thinkpad X201 Tablet RAM Replacement, RAM: passo 1, imagem 1 %32
    • Remove the battery by sliding forward the switch here.
    • For more info on how to remove the battery, refer to battery replacement guide.
  2. Lenovo Thinkpad X201 Tablet RAM Replacement: passo 2, imagem 1 %32
    • The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
    • There are only two screws to remove as circled here.
    • The screw head used here is a JIS J00 Driver.
  3. Lenovo Thinkpad X201 Tablet RAM Replacement: passo 3, imagem 1 %32
    • On the edges of the RAM components, push each switch to the side.
    • The RAM chip should pop up on its own once you push each side outwards.
  4. Lenovo Thinkpad X201 Tablet RAM Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X201 Tablet RAM Replacement: passo 4, imagem 2 %32
    • The RAM chip should pop up on its own once the sides are pushed outwards.
    • Gently pull on the RAM to remove.
  5. Lenovo Thinkpad X201 Tablet RAM Replacement: passo 5, imagem 1 %32
    • Remove the RAM from the device.
Conclusão
Peter Gachuki
Membro desde: 03/26/18
642 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S5-G7, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G7, Peak Spring 2018
UMASSD-PEAK-S18S5G7
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,024
