Ir para o conteúdo principal
Lenovo Thinkpad X201 Tablet LCD Replacement
O que você precisa
  1. Lenovo Thinkpad X201 Tablet LCD Replacement, LCD: passo 1, imagem 1 %32
    • First you push the lock button on the back of the computer from lock to unlock
  2. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 2, imagem 1 %32
    • Then you hold it on unlocked and slide the battery pack out
  3. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 3, imagem 1 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 3, imagem 2 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 3, imagem 3 %32
    • remove all screw covers above hinges
  4. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 4, imagem 2 %32
    • Unscrew the screws on the front of the LCD screen
  5. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 5, imagem 2 %32
    • Remove additional two screws near bezel screws plus the single logic board screw in the center
  6. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 6, imagem 1 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 6, imagem 2 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 6, imagem 3 %32
    • Gently pry the LCD cover with a flat head screwdriver, and pivot it over the signal cable near the LCD hinges. Pivot over all four corners
  7. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 7, imagem 1 %32 Lenovo Thinkpad X201 Tablet LCD Replacement: passo 7, imagem 2 %32
    • Continue to remove screens in front of the LCD cover, make sure all screws in the front are removed
  8. Lenovo Thinkpad X201 Tablet LCD Replacement: passo 8, imagem 1 %32
    • Once all screws are removed, remove the LCD Display but gently peeling back line a sticker
Conclusão
Peter Gachuki
Membro desde: 03/26/18
642 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S5-G7, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G7, Peak Spring 2018
UMASSD-PEAK-S18S5G7
Membros da 3
Autoria de 12 guias
Um comentário
Is there any other screen that can be used?
Darren Lewis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 27
Duração total: 3,130
