Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will take you through how to replace the keyboard in your Lenovo ThinkPad X201 Tablet if it is broken or damaged.
Peças
Nenhum componente especificado.
  1. First you push the lock button on the back of the computer from lock to unlock.
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Then you hold it on unlocked and slide the battery pack out.
    • Then you hold it on unlocked and slide the battery pack out.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them. Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  5. Using your fingers push keyboard forward so it is closer to the screen than it was before
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  6. Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Conclusão
Uma outra pessoa concluiu este guia.
Thomas Donahue
Membro desde: 20-03-2018
474 Reputação
2 Guias de autoria
equipe
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 57
Duração total: 1,006
