Ir para o conteúdo principal
Lenovo Thinkpad X201 Tablet Keyboard Replacement
O que você precisa
  1. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • First you push the lock button on the back of the computer from lock to unlock.
  2. Lenovo Thinkpad X201 Tablet Keyboard Replacement: passo 2, imagem 1 %32
    • Then you hold it on unlocked and slide the battery pack out.
  3. Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Lenovo Thinkpad X201 Tablet Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Using a Phillips #00 screwdriver unscrew the four screws in the back of the laptop that have a keyboard symbol next to them.
  4. Lenovo Thinkpad X201 Tablet Keyboard Replacement: passo 4, imagem 1 %32
    • Using your fingers push keyboard forward so it is closer to the screen than it was before
  5. Lenovo Thinkpad X201 Tablet Keyboard Replacement: passo 5, imagem 1 %32
    • Use a flathead screwdriver to gently lift up on the keyboard until it comes off. Make sure you disconnect the ribbon cable from the motherboard before removing the KB completely.
Conclusão
Uma outra pessoa concluiu este guia.
Thomas Donahue
Membro desde: 03/20/18
474 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S5-G7, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G7, Peak Spring 2018
UMASSD-PEAK-S18S5G7
Membros da 3
Autoria de 12 guias
Um comentário
Excellent.. thank you.. I just put on my new keyboard. I appreciated seeing your photos just to make sure I didn’t miss anything.
Andy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 2,378
