Ir para o conteúdo principal
Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement
O que você precisa
  1. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Bottom Panel: passo 1, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 2, imagem 1 %32
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Wireless LAN Card: passo 3, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement, Wireless LAN Card: passo 3, imagem 2 %32
    • Remove the protective film to the left of the fan assembly.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 4, imagem 2 %32 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 4, imagem 3 %32
    • Carefully disconnect the gray and black antenna connectors on the green wireless LAN card by lifting under the antennas with an opening tool.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 5, imagem 1 %32
    • Remove the 2.5 mm screw holding the card in place with a Phillips #1 screwdriver.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 6, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Wireless LAN Card Replacement: passo 6, imagem 2 %32
    • Carefully slide the wireless card out of the slot by pulling it to the right.
Conclusão
Uma outra pessoa concluiu este guia.
Alexander Davis
Membro desde: 01/23/20
1.093 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S1-G4, White Winter 2020 Membro de Cal Poly, Team S1-G4, White Winter 2020
CPSU-WHITE-W20S1G4
Membros da 3
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 37
Duração total: 2,042
