Ir para o conteúdo principal
Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement
O que você precisa
  1. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Bottom Panel: passo 1, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
    • The screws do not fully come out of the back cover, so there is no need for screw management.
    • There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
  2. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 2, imagem 1 %32
    • Lift the back cover up and off of the computer.
  3. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Peel off the black protective film to the left of the fan.
  4. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 4, imagem 2 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 4, imagem 3 %32
    • Do not remove the four screws closest to the fan. They do not affect the fan assembly.
    • Disconnect the antenna wires on green the wireless LAN card to the left of the fan.
  5. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 5, imagem 2 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 5, imagem 3 %32
    • Lift up the hinge connector that is attached to the fan's ribbon cable.
    • Carefully disconnect the cable by pulling outwards from the ribbon connector.
  6. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 6, imagem 1 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 6, imagem 2 %32 Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 6, imagem 3 %32
    • Loosen the screws on the 'x' configuration of metal.
    • These screws are held on to the metal 'x', so don't worry about them falling out.
  7. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 7, imagem 1 %32
    • Lift the fan upwards from the board.
  8. Lenovo Thinkpad X1 Carbon 4th Gen Fan Replacement: passo 8, imagem 1 %32
    • It's best practice to replace the old thermal paste under the 'x' configuration of metal. (Guides on how to replace thermal paste can be found here.)
Conclusão
Alexander Davis
Membro desde: 01/23/20
1.114 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S1-G4, White Winter 2020 Membro de Cal Poly, Team S1-G4, White Winter 2020
CPSU-WHITE-W20S1G4
Membros da 3
Autoria de 19 guias
2 comentários
I bought a refurbished Lenovo from Ebay and it purports to be a Carbon X1 4th Gen, but its guts do not look like the ones depicted in the photo. Instead, it looks like https://davidmintz.org/images/20210703_l.... Nevertheless I was able to remove the fan — the general idea is similar enough. After three or so years this machine has died with a simple “Fan error” message at boot time. I tried blowing out some dust and trying again, no luck. So I will be looking for the replacement part. Wish me luck. Thank you for the guide!
David Mintz - Responder
Very useful and allowed me to clean the fan on my 4th gen X1 Carbon. That fixed the immediate "fan error" message on boot failure. It is running rough so I will have to replace it soon I think.
Edwin Blake - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 153
Duração total: 6,645
