Ir para o conteúdo principal
Lenovo Thinkpad Twist s230u Upper Casing Replacement
O que você precisa
  1. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 2, imagem 1 %32
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 3, imagem 1 %32
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 4, imagem 2 %32
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Keyboard: passo 5, imagem 1 %32
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 6, imagem 1 %32
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 7, imagem 1 %32
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 8, imagem 1 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 8, imagem 2 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 8, imagem 3 %32
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Upper Casing Replacement, Upper Casing: passo 9, imagem 1 %32
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 10, imagem 1 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 10, imagem 2 %32
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 11, imagem 1 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 11, imagem 2 %32
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 12, imagem 1 %32 Lenovo Thinkpad Twist s230u Upper Casing Replacement: passo 12, imagem 2 %32
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 964
