Ir para o conteúdo principal
Lenovo Thinkpad Twist s230u Keyboard Replacement
O que você precisa
  1. Lenovo Thinkpad Twist s230u Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  2. Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 2, imagem 1 %32
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  3. Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 3, imagem 1 %32
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  4. Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 4, imagem 2 %32 Lenovo Thinkpad Twist s230u Keyboard Replacement: passo 4, imagem 3 %32
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 1,135
