Ir para o conteúdo principal
Lenovo Thinkpad Twist s230u Hard Drive Replacement
O que você precisa
  1. Lenovo Thinkpad Twist s230u Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo Thinkpad Twist s230u Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Hard Drive Replacement: passo 2, imagem 1 %32
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Hard Drive Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad Twist s230u Hard Drive Replacement: passo 4, imagem 2 %32
    • Remove the hard drive by sliding it out.
Conclusão
4 outras pessoas executaram este guia.
Um comentário
Thank you this helped a great deal by just reinforcing that it was as simple as I thought, too bad the cloning did not go as well :)
S C - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 1,887
