Ir para o conteúdo principal
Lenovo Thinkpad T450s Trackpad Replacement
O que você precisa
  1. Lenovo Thinkpad T450s Trackpad Replacement, Trackpad: passo 1, imagem 1 %32
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Trackpad Replacement: passo 2, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back cover and remove the back cover.
  3. Lenovo Thinkpad T450s Trackpad Replacement: passo 3, imagem 1 %32 Lenovo Thinkpad T450s Trackpad Replacement: passo 3, imagem 2 %32
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Trackpad Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad T450s Trackpad Replacement: passo 4, imagem 2 %32 Lenovo Thinkpad T450s Trackpad Replacement: passo 4, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the three 5mm screws around the battery.
    • Unplug and remove the battery.
  5. Lenovo Thinkpad T450s Trackpad Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad T450s Trackpad Replacement: passo 5, imagem 2 %32 Lenovo Thinkpad T450s Trackpad Replacement: passo 5, imagem 3 %32
    • Remove the ten 5mm screws holding down the motherboard using the Phillips #0 screwdriver.
  6. Lenovo Thinkpad T450s Trackpad Replacement: passo 6, imagem 1 %32
    • Remove the flat flex cable that connects the touchpad to the laptop.
  7. Lenovo Thinkpad T450s Trackpad Replacement: passo 7, imagem 1 %32 Lenovo Thinkpad T450s Trackpad Replacement: passo 7, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the single screw holding the hard drive.
    • Remove the hard drive from the device.
  8. Lenovo Thinkpad T450s Trackpad Replacement: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the two 5mm screws that connects the toughpad to the computer.
  9. Lenovo Thinkpad T450s Trackpad Replacement: passo 9, imagem 1 %32
    • Remove the cable in the left hand of this picture that connects the motherboard to hard drive.
  10. Lenovo Thinkpad T450s Trackpad Replacement: passo 10, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the the two 5mm screws in this image and then remove the glue flex cable being held.
  11. Lenovo Thinkpad T450s Trackpad Replacement: passo 11, imagem 1 %32
    • Flip the laptop and remove the touchpad, it will pop right out.
Conclusão
5 outras pessoas executaram este guia.
Nathan Morgan
Membro desde: 11/11/19
469 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G5, Stella Fall 2019 Membro de IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
Membros da 3
Autoria de 2 guias
4 comentários
Hello,
I would like to ask you one thing - do you recall if the TouchPad can be adjusted (position wise) before srewing down? I have this problem where the right side on the TouchPad is too close to the palmrest (between spacebar and the TrackPoint buttons), and when I click the right physical button it collides with it, providing not so great using experience. So I was wondering it is posiible to losen the screws and move it back a little.
Is it possible? Thanks in advance for answear.
Adrian Wiechnik - Responder
Do I have to reinstall drivers after this? I replaced the touchpad but now two fingers scrolling is not working. Any ideas?
Manuel Amaro - Responder
Do I have to remove the keyboard to replace the touchpad for thinkpad t450?
It does not seem necessary when following the instructions above!
TheTruthWillSetYouFree - Responder
Will post here again to warn people. Be very careful when removing the flat flex glue cable that attaches to the motherboard. The clamp can easily be damaged by just manipulating the cable. Make sure to open the clamp first before removing or the clamp may break and will not be able to be replaced other than replacing the main board!
PC Fixer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 27
Duração total: 4,959
