Ir para o conteúdo principal
Introdução
If your device is failing to successfully connect to any wireless network you can find step by step instructions in this guide on how to replace your Network adapter.
Peças
Nenhum componente especificado.
  1. Turn off device before starting Flip the laptop upside down so you have access to the battery.
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Slide lock button 1 to the unlock position and gently slide away from your body.
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed. Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  5. Flip the device over and lay it down with the underside facing upwards. Unscrew all 7 screws. Note that they do not come out completely.
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 7 screws. Note that they do not come out completely.
  6. Pry the bottom from the computer until it pops out.
    • Pry the bottom from the computer until it pops out.
  7. Remove the single 3mm screw holding the network adapter in place. You will have to locate and lift up a small, black area of film covering the screw and network adapter.
    • Remove the single 3mm screw holding the network adapter in place.
    • You will have to locate and lift up a small, black area of film covering the screw and network adapter.
  8. Remove the two cables connected (1 black, 1 grey) from the network adapter.
    • Remove the two cables connected (1 black, 1 grey) from the network adapter.
    • The cables will pop off once the screw is removed.
  9. Pull the network adapter out of the device.
    • Pull the network adapter out of the device.
Conclusão
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 37
All Time: 176
