Ir para o conteúdo principal
Introdução
If you are encountering issues with your keyboard, there is a possibility that you might have to replace it. You can utilize this guide to receive step by step instruction to complete this task manually by yourself.
Peças
Nenhum componente especificado.
  1. Remove the battery by pulling on the two sliding buttons next to the battery.
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver. Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Remove the two rubber stoppers from  where the battery previously was.
    • Remove the two rubber stoppers from where the battery previously was.
  4. Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard. Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lift the keyboard and flip over exposing the connection to the motherboard.
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Remove the plastic covering and detach touch point and keyboard cable.
    • Remove the plastic covering and detach touch point and keyboard cable.
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Morgan
Membro desde: 11/11/2019
403 Reputação
2 Guias de autoria
Equipe
IUPUI, Team S2-G5, Stella Fall 2019 Membro de IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Membros
2 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 30
Últimos 30 dias: 122
Duração total: 1,950
