Ir para o conteúdo principal
Lenovo Thinkpad T450s Fan Replacement
O que você precisa
  1. Lenovo Thinkpad T450s Fan Replacement, Fan: passo 1, imagem 1 %32
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Fan Replacement: passo 2, imagem 1 %32
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Fan Replacement: passo 3, imagem 1 %32
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Fan Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Murphy Derwent
Membro desde: 04/05/22
130 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-3, Harley Spring 2022 Membro de IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 36
Duração total: 1,243
