Ir para o conteúdo principal
Lenovo Thinkpad T450s Bottom Panel Removal
O que você precisa
  1. Lenovo Thinkpad T450s Bottom Panel Removal, Battery: passo 1, imagem 1 %32 Lenovo Thinkpad T450s Bottom Panel Removal, Battery: passo 1, imagem 2 %32
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Lenovo Thinkpad T450s Bottom Panel Removal: passo 2, imagem 1 %32
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  3. Lenovo Thinkpad T450s Bottom Panel Removal: passo 3, imagem 1 %32 Lenovo Thinkpad T450s Bottom Panel Removal: passo 3, imagem 2 %32
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
  4. Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, imagem 1 %32 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, imagem 2 %32 Lenovo Thinkpad T450s Bottom Panel Removal, Lenovo Thinkpad T450s Bottom Panel Removal: passo 4, imagem 3 %32
    • Flip the device over and lay it down with the underside facing upwards.
    • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
  5. Lenovo Thinkpad T450s Bottom Panel Removal: passo 5, imagem 1 %32 Lenovo Thinkpad T450s Bottom Panel Removal: passo 5, imagem 2 %32
    • Pry the bottom from the computer until it pops out.
    • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 3,664
