Introdução
If you're needing to replace the battery on your Thinkpad, you can find instructions on how to do so in this repair guide. No tools will be needed to complete the following steps.
Ferramentas
Peças
Nenhum componente especificado.
  1. Turn off device before starting Flip the laptop upside down so you have access to the battery.
    • Turn off device before starting
    • Flip the laptop upside down so you have access to the battery.
  2. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  3. Slide lock button 1 to the unlock position and gently slide away from your body.
    • Slide lock button 1 to the unlock position and gently slide away from your body.
  4. Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed. Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
    • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
Conclusão
Uma outra pessoa concluiu este guia.
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 51
All Time: 265
