Ir para o conteúdo principal
Lenovo Thinkpad T440s Keyboard Replacement
O que você precisa
  1. Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Start with the laptop open and the keyboard exposed.
  2. Lenovo Thinkpad T440s Keyboard Replacement: passo 2, imagem 1 %32 Lenovo Thinkpad T440s Keyboard Replacement: passo 2, imagem 2 %32 Lenovo Thinkpad T440s Keyboard Replacement: passo 2, imagem 3 %32
    • Use the metal spudger to press the keyboard plate forward towards the display
  3. Lenovo Thinkpad T440s Keyboard Replacement: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdrivers to remove the six screws holding in the keyboard.
  4. Lenovo Thinkpad T440s Keyboard Replacement: passo 4, imagem 1 %32 Lenovo Thinkpad T440s Keyboard Replacement: passo 4, imagem 2 %32 Lenovo Thinkpad T440s Keyboard Replacement: passo 4, imagem 3 %32
    • Use the metal spudger to lift up the keyboard plate.
    • Run the metal spudger around the plate, applying light pressure until the keyboard pops out.
  5. Lenovo Thinkpad T440s Keyboard Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad T440s Keyboard Replacement: passo 5, imagem 2 %32 Lenovo Thinkpad T440s Keyboard Replacement: passo 5, imagem 3 %32
    • The keyboard can now be rested forward to expose the ribbon cable attaching it to the motherboard.
    • The ribbon cable will come out with a light pull in the opposite direction of its connection.
    • The keyboard is now removed and ready to be replaced.
Conclusão
5 outras pessoas executaram este guia.
Terelle Montalvo
Membro desde: 10/22/18
1.477 Reputação
Autoria de 8 guias
Equipe
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Membro de UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
Membros da 3
Autoria de 8 guias
Um comentário
how can i get a video for guideline?
Taiye Phisical - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 79
Duração total: 5,398
