Introdução
Is your laptop heating up too quickly or making loud noises? Consider using this guide to replace the fan in your device.
O que você precisa
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
Use the Phillips #1 screwdriver to remove the four screws holding in the fan assembly.
6 outras pessoas executaram este guia.
4Comentários do guia
What about thermal grease?
Useless info. This is the heatsink (with fan) replacement, NOT fan replacement. The poster is a moron.
Victor - The fan and heatsink are attached to one another. How would you propose one replace the fan only? If you have a method, please create your own guide if this one was authored by such a “moron”. Jeez.
