Ir para o conteúdo principal
Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement
O que você precisa
  1. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Set to Maintenance Mode: passo 1, imagem 1 %32
    • While booting, press the F1 button to enter the BIOS.
    • Go to "Config" and then to "Power".
    • Select "Disable Built-in Battery" and press Enter.
    • You will be asked to proceed. Select "Yes".
    • The laptop shuts down.Unplug the laptop from AC.
    • Remove the battery.
  2. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: passo 2, imagem 1 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: passo 2, imagem 2 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Front Bezel: passo 2, imagem 3 %32
    • Start removing the front bezel in the lower display corners using a prying tool.
    • Make sure the glue and tape will stick to the front bezel instead of the display and rear bezel. You can use a gripping tool and a cutter for this.
  3. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Screws: passo 3, imagem 1 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Screws: passo 3, imagem 2 %32
    • Remove 4 screws M2XL3 with screwdriver.
  4. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Rear Bezel: passo 4, imagem 1 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Remove Rear Bezel: passo 4, imagem 2 %32
    • Remove the rear bezel with the prying tool.
    • Make shure you do not move or damage the blue and black cable behind the bezel.
  5. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: passo 5, imagem 1 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: passo 5, imagem 2 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release Display: passo 5, imagem 3 %32
    • Carefully release the display, turn it around and place it on the keyboard.
    • Ensure to not damage the connector on the lower part of the display.
  6. Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release the Connector: passo 6, imagem 1 %32 Lenovo Thinkpad T440s Display (Full-HD, no touch) Replacement, Release the Connector: passo 6, imagem 2 %32
    • Remove the connector together with the label.
Conclusão
18 outras pessoas executaram este guia.
Markus Schmidt
Membro desde: 06/07/15
689 Reputação
Autoria de 1 guia
7 comentários
Did this upgrade with my T440 and worked great, used a LP140WF1 / B140HAN01 display added some much needed pixels and IPS viewing angles. I bought from Aliexpress Store: Kevin trade shop.
Ryan - Responder
What about T440s with touch panel?
TINGHUI WANG - Responder
I do not possess a touch device, sorry.
Markus Schmidt -
Can this be done as an upgrade
Randall Bickford - Responder
You mean from “normal” to touch display? I cannot comment on a touch device…
Markus Schmidt -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 89
Duração total: 31,343
