Introdução
Is your device turning off unexpectedly or not properly holding a charge? Consider using this guide to replace the battery in your device.
O que você precisa
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
Use the Phillips #1 screwdriver to remove the three screws holding in the battery.
3 outras pessoas executaram este guia.
