O que você precisa
Flip the laptop over.
Place it on a flat, sturdy surface.
Remove the battery by moving the battery latch and slowly sliding the battery out.
Locate the drive enclosure.
Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
Carefully remove the drive enclosure cover.
to avoid breaking those latches, the cover doesn’t come off in a straight line, it comes out sliding from the screw side rotating the cover around the other end (the end near the laptop corner area). If stuck, use the screwdriver to continually turn the screw counterclockwise while pulling. JD
Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
If for some reason your hard drive doesnt have the ribbon then you better have a pair of tweezers and alot of patience, but with some rocking back and forth and a tight grip, you should be able to remove it
Remove the plastic rails from the old drive and place them on the new drive.
37 outras pessoas executaram este guia.
Um comentário
If the pull tab is not present - probably due to the drive being replaced - it is possible with care to put the tip of a screwdriver into the rubber side rails and pull the unit out
