Ir para o conteúdo principal
Lenovo Thinkpad Edge E40 Bottom Cover Replacement
O que você precisa
  1. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop over.
    • Unplug all cables from the computer. If you're just swapping the battery, you can leave the power cord plugged in.
  2. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Battery: passo 2, imagem 1 %32
    • Pull the locking tab on the battery towards the unlock position.
    • Pull the battery out of the socket.
  3. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Bottom Cover: passo 3, imagem 1 %32
    • Loosen the following five screws:
    • 5 Phillips #0 screws
    • 1 recessed Phillips #0 screw
    • These screws do not come out all the way, and need to be un-tightened a lot more than you might think.
  4. Lenovo Thinkpad Edge E40 Bottom Cover Replacement, Bottom Cover: passo 4, imagem 1 %32
    • Pull up on the front cover from the left and right sides.
    • Do not force the cover off the laptop. If it does not want to come out, undo the screws a bit more.
Conclusão
DistroHopper39B
Membro desde: 05/30/20
406 Reputação
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 63
