Ir para o conteúdo principal
Lenovo Thinkpad E585 Hard Drive Replacement
O que você precisa
  1. Lenovo Thinkpad E585 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Remove the marked Screws.
    • Pry the backside of and put it aside.
  2. Lenovo Thinkpad E585 Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo Thinkpad E585 Hard Drive Replacement: passo 2, imagem 2 %32
    • Pull gently on the marked pull tab. If it doesn't come out, pull harder.
    • After you pulled the Hard Drive Dummy out, remove the Connector.
  3. Lenovo Thinkpad E585 Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo Thinkpad E585 Hard Drive Replacement: passo 3, imagem 2 %32
    • After the second step, you should have the dummy with the mounting hardware removed from the laptop.
    • Gently pull on the side until it comes off.
  4. Lenovo Thinkpad E585 Hard Drive Replacement: passo 4, imagem 1 %32
    • Put your hard drive in the middle of the mounting hardware and align the sides with the holes on the hard drive. Make sure the pull tab is on the upside.
    • Push on it.
  5. Lenovo Thinkpad E585 Hard Drive Replacement: passo 5, imagem 1 %32
    • Connect the connector.
    • Push on the ribbon cable to glue it to the underside.
  6. Lenovo Thinkpad E585 Hard Drive Replacement: passo 6, imagem 1 %32
    • Finally, align the hard drive and push on the marked end.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 1,008
