Ir para o conteúdo principal
Lenovo Thinkpad E540 WiFi Card Replacement
O que você precisa
  1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: passo 1, imagem 1 %32 Lenovo Thinkpad E540 WiFi Card Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 WiFi Card Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: passo 3, imagem 1 %32
    • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
  4. Lenovo Thinkpad E540 WiFi Card Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to remove panel.
  5. Lenovo Thinkpad E540 WiFi Card Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad E540 WiFi Card Replacement: passo 5, imagem 2 %32
    • Disconnect the two antenna cables from the wifi card.
    • Remove the single 1mm Phillips #0 screw from the wifi card.
  6. Lenovo Thinkpad E540 WiFi Card Replacement: passo 6, imagem 1 %32
    • Remove the wifi card by sliding it out.
Conclusão
3 outras pessoas executaram este guia.
Timothy Sumner
Membro desde: 02/14/18
1.052 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membro de USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Membros
Autoria de 8 guias
2 comentários
Pictures show battery is still connected to laptop.
Monte Christo - Responder
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 11
Últimos 30 dias: 25
Ao todo: 3,206
