Pular para o conteúdo principal
Introdução
A guide on how to replace the individual keys on a Lenovo ThinkPad E540 laptop.
Peças
Nenhum componente especificado.
  1. Push the battery release switches away from each other. Push the battery release switches away from each other.
    • Push the battery release switches away from each other.
  2. Remove the battery.
    • Remove the battery.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Push the keyboard forward towards the display to create a gap above the trackpad.
    • Push the keyboard forward towards the display to create a gap above the trackpad.
  5. Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
    • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
  6. Tilt the keyboard forward from the top and lift gently.
    • Tilt the keyboard forward from the top and lift gently.
    • Dont pull too far because there is a cable attached to the back.
  7. Use a spudger to lift the black latch on the ZIF connectors. Remove the blue and purple ribbon cables from the ZIF connectors.
    • Use a spudger to lift the black latch on the ZIF connectors.
    • Remove the blue and purple ribbon cables from the ZIF connectors.
Conclusão
Timothy Sumner
Membro desde: 14-02-2018
947 reputação
8 Guias de autoria
Equipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membro de USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Membros
8 Guias de autoria
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - Responder
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 56
Últimos 30 dias: 214
Todo: 2,307
