Ir para o conteúdo principal
Lenovo Thinkpad E540 Keyboard Replacement
O que você precisa
  1. Lenovo Thinkpad E540 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Lenovo Thinkpad E540 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. Lenovo Thinkpad E540 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Push the keyboard forward towards the display to create a gap above the trackpad.
  4. Lenovo Thinkpad E540 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
  5. Lenovo Thinkpad E540 Keyboard Replacement: passo 5, imagem 1 %32
    • Tilt the keyboard forward from the top and lift gently.
    • Dont pull too far because there is a cable attached to the back.
  6. Lenovo Thinkpad E540 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo Thinkpad E540 Keyboard Replacement: passo 6, imagem 2 %32
    • Use a spudger to lift the black latch on the ZIF connectors.
    • Remove the blue and purple ribbon cables from the ZIF connectors.
Conclusão
Timothy Sumner
Membro desde: 02/14/18
1.046 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membro de USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
Membros da 4
Autoria de 8 guias
4 comentários
Thank you for posting this guide. I was able to comfortably replace my keyboard on a Lenovo E540 Thinkpad after I spilled a full glass of water on it. I was able to get a replacement keyboard via AliExpress for $25.84USD -- I initially considered buying a replacement from eBay but the keyboard prices were half of the laptop's current value, which is a bit silly.
Thank you Timothy Sumner, you’re a legend! :)
Zeeshan Muhammad - Responder
These instructions are miserably wrong for the model E540 20C6-008SUS. The keyboard is completely covered by a plastic grid that fills the large gaps between the keys. The keyboard hold-down screws are hidden by this grid. YOUR OWN PHOTO CLEARLY SHOWS THIS ! Furthermore, the keyboard can not be pushed “forward towards the display to create a gap above the trackpad “ simply because the 4 screws are holding it solidly in place. This plastic grid must be carefully pried up and out to expose the keyboard screws enough to be able to get a screwdriver in position over the screw heads.
Hewey Dewey - Responder
With my edge 540 (submodel unknown) I was able to reach the screws by pushing the screw driver under the plastic grid. It did however slightly scuff up my F key
Dick van Zalinge -
You forgot the latch underneath the main battery.
Moose Technologies - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 45
Duração total: 10,357
