Ir para o conteúdo principal
Lenovo Thinkpad E540 Hard Drive Replacement
O que você precisa
  1. Lenovo Thinkpad E540 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Lenovo Thinkpad E540 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. Lenovo Thinkpad E540 Hard Drive Replacement, Disassembly of the Back Panel: passo 3, imagem 1 %32
    • Remove the three 1.2mm Phillips #00 screws from the bottom panel.
    For me a Phillips #1 was the first bit with a tight fit (testet PH #00, #0, #1).
    Till - Responder
  4. Lenovo Thinkpad E540 Hard Drive Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry off the bottom panel.
  5. Lenovo Thinkpad E540 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove the four 1.2mm Phillips #0 screws from the hard drive.
  6. Lenovo Thinkpad E540 Hard Drive Replacement: passo 6, imagem 1 %32
    • Pull up on the hard drive to allow for removal.
  7. Lenovo Thinkpad E540 Hard Drive Replacement: passo 7, imagem 1 %32
    • Disconnect the hard drive and pull out to remove.
Conclusão
4 outras pessoas executaram este guia.
Timothy Sumner
Membro desde: 02/14/18
1.040 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team S2-G5, Nance Spring 2018 Membro de USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
Membros da 4
Autoria de 8 guias
Um comentário
Thanks for this invaluable and easy guide.
Is it possible to replace the hdd with an ssd for this model? If so, which ssd would fit this laptop’s hdd socket?
Many thanks in advance.
SKP - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 5,361
